Power Timer
1 TopicPower Timer not turning on OS6 FW 6.4.1 - Legacy Ultra 6
I recently acquired an Ultra 6 Plus, which I upgraded to OS 6, FW 6.4.1, for use in backups. The Power Timer function (which I liked better in the old NV+ models, since I could specify minutes) turns the U6+ off, but does not turn it on. I'm currently using a cron entry on my DD-WRT router to do a WOL job to turn the U6+ on at the specified time (3:50am). Needless to say, it's a fix smacking of Rube Goldberg, though not as good as the one in this simple alarm clock (No, this is NOT my proposed fix, perfume is expensive, and so are cannonballs). Hardware: ReadyNAS Ultra 6 Plus Firmware: 6.4.1 Time: correct Power Timer: currently 2am to 11am (so I can verify it turned on for to do backups, will shorten to 6 or 7am when assured of regular backups) Backup jobs: currently 4am to 6am (rsync pulls) WOL: enabled DD-WRT router cron WOL job: 3:50AM Ay suggestions on how I can fix this? I'm willing to SSH in if need be, but not completely comfortable in linux. -kevinb1 (formerly imsai on infrant/netgear, how do I change my handle back?) P.S. I'm also getting fan underspeed warnings, but one thing at a time....Solved
