Power Timer
2 TopicsAny way to turn off power alerts?
Now that all our backup jobs are working properly, our 104 is on a nightly power timer. Is there any way to turn off the daily "The system is shutting down." emails I'm getting now? The check box for this is grayed out: I want to keep getting email alerts but don't need a daily reminder that the power timer is working properly. Any suggestions? Thanks!Solved2KViews0likes3CommentsFW 6.4.1 Problems: Power Timer not working
Firstly, you need to know that I'm using a RN102, obviously with FW 6.4.1 loaded. Mostly I'm pleased with the changes made so far, but there are two problems which do need to be solved: As so many have reported, there is a serious speed issue, unless the AV software is turned off. The Power Timer appears to be entirely unresponsive - my backups are working as scheduled, even though the power should be shut off at the time. There is no log entry for shutdown or restart. This is inconvenient at Chrismas with a granddaughter sleeping in my study! Is there an easy solution? Scads2.9KViews0likes7Comments
