Primary WAN
1 TopicIPV6 in load balancing mode on SRX5308
If you have more them one internet connect you cannot use IPV6, because IPV6 is only available in Primary WAN Mode. Also you lose all you’re settings when you change from Load Balancing to Primary WAN Mode or from Primary WAN to Load Balancing Mode, which is very frustrating.20KViews2likes2Comments
