R7000
1 TopicWAC 510 Firmware Upgrades
I have two Netgear WAC 510 acess points (AP) connected to a Nighthawk R7000 wireless router. My two APs are connected and powered by POE to a 48 port Netgear switch. Everything is working fine which I know is an odd way to start a conversation with this community. Today I decided to check the firmware version of my APs. I logged in to them and both were at version 4.0.7.3. I clicked the box to check for updates and the reply I got back was there were no updates available. I doubted that because I have not accessed those APs in over 6 years. I checked the Netgear Product Support pages for the WAC 510. The latest Firmware and MIB version is 9.9.6.8. There are 56 updates for Firmware and MIB from where I am at 4.0.7.3!! A few questions for the Community: Why didn't the hardware automatically get those updates as they came out an apply them? If it's not broke, don't fix it. Should I just leave things alone and wait a year until I am ready to upgrade to WiFi 7? If there is a reason to take on this firmware upgrade task (times two APs), is there an easier way to get from 4.0.7.3 to 9.9.6.8 than applying each update in order?? Thanks in advance, ZaffySolved376Views0likes3Comments
