R7100P
2 TopicsLACP on gigabit ethernet port for R7000P and above
Hello, The device is really cool but I can't understand why there is no LACP... Wifi is faster than the gigabit ethernet ports? Is it really ok for you? I really hope there will be a LACP version of this model, or maybe better... a new firmware with this option. It should be so great for home NAS to perform in good condition HD streaming. Secondly, is it possible to connect a 4G router (netgear AC810AC) on USB3 to make a internet "failover". It should be great too. Thanks for reading me. And thank for the goos job you make on these products. Kind Regards, Nicolas.9.7KViews1like0CommentsRouter R7100P and AirCard 810 on USB3 ? (request upgrade)
Hello, I have a router R7000P and a AirCard 810(EUS)... Both are Netgear devices so I wished it can be compatible. Is it possible for the development team to make this router able to connect to the AirCard to increase the bandwidth (load balancing mode.... maybe bonding if it is possible?) in additionning the DSL (via ethernet) and LTE-A (via USB). Else it can be a very good way for a failover mode. Waiting for some answer. Maybe I'm not alone to want this kind of feature? Kind regards.12KViews0likes0Comments
