R7900
8 TopicsNighthawk AC1900 Smart WiFi Router (R6900P) in AP Mode, Second R6900P
All connections are Ethernet. Buried Ethernet and feeder cable to buildings #2 and #3; Ethernet and utility feeder cabling are ~12" separation as appropriate. Router is Nighthawk X6S, AC3600 (Model 7960), connected to fiber. Additional hardware in network: 2-WAC104 in AP mode, building #1; 1-WAC104 in AP mode (building #2), Model R6900P in AP mode, building #2. I want to add a second Model R6900P in AP mode in building #3. Multiple 8-port Netgear GS108 switches. ALL devices share same SSID. This is a problem of longstanding, I go back to from time to time. Hoping. (I admit I am not the sharpest knife in the drawer, network wise.) Yesterday I backed up configuration of building #2's R6900P and restored it to the building #3 R6900P. Wireless results were both mixed and inconsistent. Reading this morning I realized they were on the same Channel and Mode by my genius restore! I am confused by the Advanced | Wireless Settings (2.4GHz and 5GHz.) I did NOT try wired Ethernet connection; it was freezing and unheated. CURRENT SETTINGS: 2.4GHz: Channel - Auto (7(P)+ 11(S)); Mode - Up to 600 Mbps; Wireless AP - On; Broadcast Name - On. 5GHz: Channel - 149 + 153(P) + 157 + 161; Mode - Up to 1300 Mbps. Can you tell me what channels to set second R6900P to (Building #3)? If I connected a device via 4-integrated Ethernet ports, it would treat that R6900P as a switch, Correct? The person who did all the groundwork here passed and I don't have another local resource. TIA! FBF PS: I have screenshots of entire setup of R6900P, building #2.529Views0likes11CommentsR7960 Firmware update
Is there ANY possibility that Netgear will put thru a FIX for the R7960 router not being able to update its firmware? Mine has never worked and the links for a work around are well beyond my abilities and I am sure others too. I love the router but do not like the app or the 192.168.1.1 will not update to current functions etc. Just a shot in the dark here.205Views0likes6CommentsReplacement for R7960 router
I have never been able to update the Nighthawk R7960 router firmware and it seems this model does have an issue with this function and the work around is beyond my abilities. I cannot use the iPhone app as it cannot find the router anymore since the app updated but I could always go to 192.168.1.1 but now that function does not update as to what is currently connected and if I try to update there it also cannot find my router. The router works great--just wont update. I fear it is only time that will cause it to crash all together. In preparation for that, can you advice me as to its replacement? I have only a one story house but it has plaster walls that are thick so an entry level router might not work. I would like something as easy to install as the Nighthawk was. I really do not want to spend over $150 if I can. We have only two people in the house but guests need access. Any suggestions would be appreciated.215Views0likes4CommentsRouter with SIM Card Slot
Hello, I live in the country and don't have many internet options. My prior router took a sim card, so I need a new router that does the same. However, I am not familiar enough with routers to be able to determine which uses a sim card as opposed to ethernet. It needs to be a high speed with a wide range to reach throughout a two story house with many devices connected. If I purchase a Netgear Nighthawk R7800, will I need to purchase a modem or does it have a sim slot? If I do need to purchase a modem, am I able to use my SIM card in a Netgear modem? Any help appreciated.Solved11KViews0likes1CommentIOS Genie app with firmware 1.0.1.18
I updated my R7900 Nighthawk router to firmware 1.0.1.18 and was glad to see mobile support for VPN services. Unfortunatly, the Genie app on my phone has a few issues with this firmware. The biggest issue is I can't see the network map and therfore can't pause the cennection of specific devices (a rather important feature as I have two teenage boys at home!). I've deleted and reinstalled the app on the phone - didn't fix it. Degraded the firmware back to 1.0.1.12, it all works. Except I can't set up VPN on a mobile device now. I even went to the extent of going to .18, setting up and verifying VPN on my phone, downgrading to .12 just on the off chance the VPN would still work. As I expected, that didn't work. Has anyone else had this problem with 1.0.1.18? Any solutions? How about an app update or new firmware from Netgear??1.3KViews0likes1CommentVPN R7900 Connected to home, but no internet
hello, I was able to connect to my VPN home router in the USA. I have the R7900 Nighthawk. I followed the instructions from netgear and set up the client on my laptop abroad. I successfully connected to my router, at least by seeing the OpenVPN GUI showing green when I connect to my home router, so I assume that means I am connected via my VPN. After connecting via the VPN, I can't seem to connect to the internet via the VPN on any browser: Chrome, Firefox, Edge and I even tried Internet Explorer 11. I tried a combination of port triggering on 12974 and allowing from 500 to 1294? Just a shot in the dark. I don't know what I'm exactly doing, just trying anything. I am in Thailand now. I am trying to connect to my home VPN primarily to watch Netflix. Is this possible once I can connect to the internet after connecting the VPN? Thank you.Solved15KViews0likes5CommentsR7900 5G-2 Band Drops Speed from 200mbps to 2mbps
Hi. Over the past week I've noticed the 5G-2 band on my R7900 will drastically drop speed for no noticeable reason. Last week I change the broadcast channel from 149 to 161, which I thought was the source of the issue. Router did a soft reset after applying new channel setting and speeds went back to normal. Fast forward a week and the same drop in speed happened again. This time I just did a soft reset and left the channel the same. Speed went right back to normal after reset. 2.4G and 5G-1 bands are never impacted when the 5G-2 band is having these issues. I've tested the speeds with multiple devices ~1 foot away from the router. I'm using latest firmware (V1.0.1.4_10.0.12). Any suggestions to fix this issue? Thanks in advance.Solved6.2KViews0likes11CommentsR8000 Security Vulnerability: VU#582384 but I have a 7900
I have a Nighthawk X6 R7900 and received an email from NetGear about updating the firmware but the email only mentioned the R8000. I understand the 7900 and 8000 are similar but not sure if I am also affected and should install. Anybody know? It sure would be nice if the email also stated R7900 if that is indeed also affected. Thanks.Solved
