RN212
2 TopicsMissing Volume
I just got this thing Christmas. Got two brand new SeaGate IronHawk 4TB drives and put them in. Plugged in Ethernet. Powered up. Did the registration and everything was looking good. I poked around on the Admin page and clicked "System>Volumes" and I only see one volume in bay #2 (the picture only shows a volume in Bay # 2). So I reinsert disk #1. Still no joy. I checked the Logs tab. I see an entry "Disk: Disk Model:ST4000VN008-2DR166 Serial:WDHXXXXX was added to Channel 1 of the head unit." which is the SN for the drive in slot 1.No other errors in the logs. On the deivce, I see the LED for 1 is flashing and ACT is flashing as if somethign is happening. Not sure whats going on since thing fired right up for Disk #2 and no indication of any issues with disk 1 (just no sign of it on the volumes tab) Any pointers?Launching Plex app on RN212 evokes ERR_EMPTY_RESPONSE
I'm running the Plex app (1.0.0.2261) on my RN212 (firmware 6.5.1) and it's working fine over my network - finds and catalogs new files as I add them to Library folders etc... However - I can't access the Plex admin panel itself. I'm used to going in to RN212 Admin panel via Chrome (http://192.168.1.101/admin/) where I can see the Plex App icon under the Apps section on my System tab, and as an Installed App on the Apps tab. However in both instances... when I click the PLEX icon... instead of opening the Plex admin page, I am directed to http://192.168.1.101:32400/web where I get this error: The 192.168.1.101 page isn’t working 192.168.1.101 didn’t send any data. ERR_EMPTY_RESPONSE Followed by a Reload button. Same behavior in Firefox. Suggestions apprreciated - thanks in advance.Solved7.9KViews0likes10Comments
