PhilD_IT_Guy's avatar
PhilD_IT_Guy
Missing Volume
I just got this thing Christmas. Got two brand new SeaGate IronHawk 4TB drives and put them in. Plugged in Ethernet. Powered up. Did the registration and everything was looking good.
I poked around on the Admin page and clicked "System>Volumes" and I only see one volume in bay #2 (the picture only shows a volume in Bay # 2). So I reinsert disk #1. Still no joy. I checked the Logs tab. I see an entry "Disk: Disk Model:ST4000VN008-2DR166 Serial:WDHXXXXX was added to Channel 1 of the head unit." which is the SN for the drive in slot 1.No other errors in the logs.
On the deivce, I see the LED for 1 is flashing and ACT is flashing as if somethign is happening.
Not sure whats going on since thing fired right up for Disk #2 and no indication of any issues with disk 1 (just no sign of it on the volumes tab)
Any pointers?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    If you download the logs do you see anything for disk 1?
    Are you sure you inserted the disk correctly?
    Which firmware are you running?
    • PhilD_IT_Guy's avatar
      PhilD_IT_Guy
      After doing a factory reset everything started working correctly. But then I began transferring files onto the NAS via my PC. After about four hours of uploading there was some kind of network error that appeared on my PC (I wasn't there at the time, but I assume my PC went to sleep). I then tried to start loading files again. But the NAS would not respond. I tried to access the Admin page but it could not load (I see the webpage that says ' Connecting' but then get an response indicating that it cannot load).
      I then went to the utility room where my NAS is located and saw the power light flashing. I tried to power down by pressing the power button twice but it was unresponsive. So I pulled the plug and re-inserted it. After it powered up I tried logging in to the admin page and got the same non-response. I downloaded RAIDar and it discovered the NAS. But it says "Management Service is offline". I now have the NAS up here in my office and it appears to be trying to boot up I hear it humming and spinning and an occassion odd noise. In RAID ar I see both drives with a green checkmark icon. I am able to browse files from Windows Explorer, but cann access any of the admin screens. I am concerned that the previous issues with Disk#2 may be contributing to the issue, but I looked in the Volumes.log and I see no indication of errors. Do I just need to wait this out and see if the NAS wil let me access it eventually. Or is something totally dorked up?
ProSupport for Business
