RN31400
4 TopicsHow to force expansion in RAID-X after disk addition?
I have an RN31400 using X-RAID and the latest firmware (6.9.1). I had 4 disks, 8T8, 8Tb, 6Tb & 6Tb. I replaced the third disk with an 8Tb one, meaning I now have 8Tb, 8TB, 8Tb & 6Tb. All are WD disks on the compatibility list and are recognized fine. Using the RAID-X calculator I should have more than the 14Tb of available space, shouldn't I? It didn't increase when I swapped the 3rd disk out. It is set to RAID-X and reports RAID-5. No snapshots. Apart from factory reseting it, is there a way to force expansion? I've rebooted it, balanced it and rebooted again several times to no avail.2.6KViews0likes12CommentsFolders / files disappearing, unable to see on another Mac RN31400 – ReadyNAS 300 Series 4- Bay
I've been using my ReadyNas for over two years now with no issues, within the last 6 months it has begun to make files "disappear" until the entire drive is rebooted (this involves saving and closing all documents that are connected to the drive, quitting all programmes, relaunching the finder window, ejecting the drive itself, disconnecting myself then re-entering my log-in details. Pretty tedious when you have to do this three times a day) We have 5 people working off the ReadyNas, if someone creates a folder on their computer and asks me to access a file within that folder I follow the chain of folders to its location and can see the folder. Once I click on the folder is automatically disappears. This folder can be seen on others computers but not mine until the drive is ejected and rebooted. This happens to all five of us when someone creates a new folder / saves down a new file. Any suggestions, tips or thoughts would be hugely appreciated. Model: ReadyNas 314 RN31400 – ReadyNAS 300 Series 4- Bay (Diskless) Thanks, Melissa3.3KViews0likes7Comments
