tranqme
Aug 09, 2015Aspirant
RN31400 Power Adapter #25564575
Hello,
I'm after a replacement power adapter for a NetGear RN31400, the same as what is in the link below.
Any advice is appreciated.
Did you try Netgear support? If you are the original purchaser they should replace it if it failed.
All RN314 should still be under warranty.
- tranqmeAspirant
Yes I have, and because I purchased it second hand the warranty is non-transferable which is ridiculous.
On top of that they can't even provide me with advice on where to purchase a replacement adapter.
They really should sell some replacement parts.
Seems to me that someone from Netgear should be able to provide a link to an adapter that is compatible. 12v 7.5a isn't that rare, the main issue is making sure the output cable is compatible and has the right polarity.
- tranqmeAspirantI ended up purchasing a replacement adapter off eBay but my unit was faulty.
Where are you located? Might be able to help you out.
