tranqme
Aug 09, 2015Aspirant
RN31400 Power Adapter #25564575
Hello,
I'm after a replacement power adapter for a NetGear RN31400, the same as what is in the link below.
http://r.ebay.com/BE8Zvd
Any advice is appreciated.
Aug 10, 2015Guru - Experienced User
Did you try Netgear support? If you are the original purchaser they should replace it if it failed.
All RN314 should still be under warranty.
tranqme
Aug 11, 2015Aspirant
Yes I have, and because I purchased it second hand the warranty is non-transferable which is ridiculous.
On top of that they can't even provide me with advice on where to purchase a replacement adapter.
