tranqme
Aug 09, 2015Aspirant
RN31400 Power Adapter #25564575
Hello,
I'm after a replacement power adapter for a NetGear RN31400, the same as what is in the link below.
http://r.ebay.com/BE8Zvd
Any advice is appreciated.
Aug 10, 2015Guru - Experienced User
Did you try Netgear support? If you are the original purchaser they should replace it if it failed.
All RN314 should still be under warranty.
