ROUTER CONNECTION
1 TopicROUTER (AC1750) WINDOWS 10 LAPTOPS & WIN 7 DESKTOP WON'T CONNECT TO INTERNET
ALL OTHER DEVICES OTHER THAN ABOVE SUBJECT WILL CONNECT. Tablets; phones ARE CONNECTED. LAPTOPS IS MY PROBLEM .... MUST USE Ethernet to get online with my laptops. But, desktop can't reach same location; so as to connect. Tablets, phones ALL CONNECT great; work fine. WHAT COULD BE CAUSING THIS ISSUE. It is MOST AGGERVATING. I've tried every possible connection option. I believe it is a Windows 10 connection problem. HAS ANYONE else had THIS issue. Purchased the router last week. Tried everyway to connect. ???? ANY ADVICE from someone out there ??? I am most aggervated. ***Also can't check to see if ROUTER needs update. Because my computer shows my old Netgear router on my GENIE APP. ANY answers...ANYONE. THANX IN ADVANCE3.6KViews0likes1Comment
