Range Extener
1 TopicNETGEAR EX7000 Connection Problems
Hello Guys, i have a big issue with my Range Extender* ( EX7000). (I'm connected to the 2GEXT.) The problem is that my Labtop, Computer connects fine to the RE* ... but my other devices like my PS4, Iphone , IPad have Problems with the Connection. I solved the Problem on the I/phone/pad by typing the CLIENT-ID manually in the WLAN Settings from the RE. But on the PS4 i can't connect to the RE. I tested it via LAN and WLAN Connection.. FAILED.. But when i connect to the main WIFI Connection everything works fine.. Also tried to reset the RE Device.. same result. I also have Problems to connect on http://mywifiext.net/. My Internet explorer tells me ERR_CONNECTION_TIMED_OUT while i'm connected to the RE Device... Can anybody help me or have the same Problem with the RE EX7000 ? Thanks Rufii4.1KViews0likes3Comments
