Rufi34
Apr 19, 2017Aspirant
NETGEAR EX7000 Connection Problems
Hello Guys,
i have a big issue with my Range Extender* ( EX7000). (I'm connected to the 2GEXT.)
The problem is that my Labtop, Computer connects fine to the RE* ... but my other devices like my PS4, Iphone , IPad have Problems with the Connection.
I solved the Problem on the I/phone/pad by typing the CLIENT-ID manually in the WLAN Settings from the RE.
But on the PS4 i can't connect to the RE. I tested it via LAN and WLAN Connection.. FAILED.. But when i connect to the main WIFI Connection everything works fine..
Also tried to reset the RE Device.. same result. I also have Problems to connect on http://mywifiext.net/. My Internet explorer tells me ERR_CONNECTION_TIMED_OUT while i'm connected to the RE Device...
Can anybody help me or have the same Problem with the RE EX7000 ?
Thanks
Rufii
- DarrenMSr. NETGEAR Moderator
Hello rufi34
Have you tried to reserve the IP of the extender and the PS4?
DarrenM
