Recover data
3 TopicsReadyNAS RNDU 2120 Ultra 2 not Responding
When connected to power supply my readynas ultra 2 is just running at full speed with the fan, but it does not boot at all. I'm not able to reset it or anything. The blue power button is just lit and fan running at full speed but nothing happens. It has anything to do with whether there are disks in cabinet or not. I have two discs in it, mirrored (RAID1). I guess something in the NAS has broken (maybe due to overheat). I have lifetime family photos on it and can now not access them. Have no other backup, just the two discs in the NAS - which I hope are still are fine. What are my options for recovering the data? For info I have bought a new NAS (Synology 716+II, and also a new disc of same size as the ones in the "broken" Readynas). Any chance I will be able to read the old discs in new Synology NAS? If that will not work - Can I read and copy the old disc by connecting via SATA to a PC?Solved4.1KViews0likes9Commentsdeleted user, i can recover home folder with all data?
hi, following some evidence for the resolution of a problem sharing folders, it deleted the user from the control panel readynas. with the elimination has canceled the home directory with the data it contains. how do I retrieve the folder? it is estimated to be approximately 1 TB of data. the firmware is RAIDiator 5.3.10, the sytem has 4 disks X-RAID2 there are the tools? Help me. thank you2.8KViews0likes3CommentsRND2150 died at power outage. How to save my data?
I've had my ReadyNAS Duo 2150 since 2009. I've replaced disks a couple of times, and now I have two 1TB disks (mirrored). A couple of days ago, we had a short (2 minutes) power outage. After that the NAS won't start. Or rather, it tries to start but shuts down immediately, then tries again, and this happens over and over again. Usualy the start attempt only lasts for less than a second, but a few times it's lasted about 5 seconds. After a few attempts, it gives up and remains powered off. The start attempts include that the fan starts spinning and the blue power light goes on. The blue light fades out as the fan stops spinning. With luck, the problem is in the power adapter, and that it can be replaced. Is that a likely explanation? Are there replacements to be found somewhere? Otherwise, how do I save my data? I've searched forums, and a couple of suggestions I've found aren't really possible: * Replace the NAS with a new, identical one. They are no longer possible to buy. * Replace the NAS with a new, similar one that uses the same file system and whatever else that's required to be compatible. I can't find information about what I should look for in such an alternative NAS. * Insert the disk in a PC, and use a Linux Reader application to read the disk (http://www.diskinternals.com/linux-reader/). This requires (I assume) a stationary PC, and I don't know anyone who use a stationary PC anymore, only laptops. What can I do to recover my data?Solved4.4KViews0likes10Comments
