Rsync Backup
1 TopicRsync Backup job NAS to USB drive suddenly displaying strange behaviour
The backup job in question has been running flawlessly 3 times a day for the last year.(alongside a similar job which is not mis-behaving) The only change I have made since this began is installing OS 6.7.4 The settings are: The Source Type is "volume" and the Name is "volume: data" Everything else is blank. The Destination is Type "remote" and the Name is "remote: RSync Server", Host is "localhost" and Path is "USB_HDD_1/NAS_IAN_Backup" Under Advanced compression is disabled and Remove deleted files on target is checked. The USB Drive is NTFS format. The odd behaviour is as follows: The log shows the log as starting and completing within one second !!! and reports Backup Status: Success Which is clearly not correct. The log also shows the following: sending incremental file list sent 733 bytes received 41 bytes 1,548.00 bytes/sec total size is 2,930 speedup is 3.79 S): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/Documents, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/Downloads, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/Ians_Stuff, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/Music, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/PC_Backup, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/Pictures, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/Recovered_Data, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/Transmission, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/Videos, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/couchpotato, ACL_TYPE_ACCESS): Operation not supported (95) rsync: set_acl: sys_acl_set_file(data/sickrage, ACL_TYPE_ACCESS): Operation not supported (95) data/Documents/ data/Downloads/ data/Ians_Stuff/ data/Music/ data/PC_Backup/ data/Pictures/ data/Recovered_Data/ data/Transmission/ data/Videos/ data/couchpotato/ data/sickrage/ sent 838 bytes received 1,308 bytes 4,292.00 bytes/sec total size is 2,930 speedup is 1.37 rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.1] I am totally stumped by this and am hoping someone here can help me or better still provide a solutionSolved12KViews0likes20Comments
