Services offline
1 TopicReadynas 102 readcloud services offline
Hi all, My readynas 102 does not connect to readycloud. I had readycloud working briefly in the past, but never satisfactorily. With the OS update I was hoping to get it back working again. finally managed to upgrade to OS 6.5.0. but no matter what I do, I can not get readycloud to work. Manual is not helping, because the info is incomplete. See attached picture: I am signed into readycloud, it is on. I have a green checkmark saying "internet available", but a red cross saying "services offline". I cannot find any info on what is wrong here. My home setup is: the box from my provider (modem? Sorry I'm unfamiliar with the correct terms) then a netgear R7000 nighthawk (because the box from my provider has lousy wifi) and my readynas connected to my R7000. At first I had my readynas connected to my providers box, but then I could not access the readynas from my homenetwork. Now it is connected to my R7000. my search for answers suggested I use DNS 8.8.8.8, which might help out, but it did not. The other two are the DNS servers mentioned in my R7000. If I login to readycloud from my home network this is what I see, the shared folders "wheel" keeps spinning, but nothing happens. If I try to discover devices, it says nothing discovered. If I try to access the admin page in the readycloud webpage, this is what I get. I am at home, on the same network (my only homenetwork). I am confused... if I use the readycloud app on my ipad, it "sees" my readynas, says its online, but when I try to access it, nothing happens, but the spinning wheel if infinity.... "Trying to connect" same on my android device.... So I have no idea what I'm doing wrong, why it is not working a what I can do to sort this out. anyone any idea what is wrong, what setting I should change to get it to work? so what does the "services offline" mean, what can I do to resolve this? thank you in advanceSolved4.5KViews0likes6Comments
