HIJ
Jun 18, 2016Aspirant
Readynas 102 readcloud services offline
Hi all,
My readynas 102 does not connect to readycloud.
I had readycloud working briefly in the past, but never satisfactorily. With the OS update I was hoping to get it back working again. finally managed to upgrade to OS 6.5.0.
but no matter what I do, I can not get readycloud to work. Manual is not helping, because the info is incomplete.
See attached picture: I am signed into readycloud, it is on. I have a green checkmark saying "internet available", but a red cross saying "services offline". I cannot find any info on what is wrong here.
My home setup is: the box from my provider (modem? Sorry I'm unfamiliar with the correct terms) then a netgear R7000 nighthawk (because the box from my provider has lousy wifi) and my readynas connected to my R7000. At first I had my readynas connected to my providers box, but then I could not access the readynas from my homenetwork. Now it is connected to my R7000.
my search for answers suggested I use DNS 8.8.8.8, which might help out, but it did not. The other two are the DNS servers mentioned in my R7000.
If I login to readycloud from my home network this is what I see, the shared folders "wheel" keeps spinning, but nothing happens.
If I try to discover devices, it says nothing discovered.
If I try to access the admin page in the readycloud webpage, this is what I get. I am at home, on the same network (my only homenetwork). I am confused...
if I use the readycloud app on my ipad, it "sees" my readynas, says its online, but when I try to access it, nothing happens, but the spinning wheel if infinity.... "Trying to connect"
same on my android device....
So I have no idea what I'm doing wrong, why it is not working a what I can do to sort this out.
anyone any idea what is wrong, what setting I should change to get it to work?
so what does the "services offline" mean, what can I do to resolve this?
thank you in advance
Hi Brian,
OK, so I found that the proxy server was ticked. I unticked it and readycloud seems to be working again. I have not been able to try it from another network, only at home, so let me report back once that is done.
so far so good!
regards, HIJ
- BrianL2NETGEAR Employee Retired
Hi HIJ,
Welcome to the community!
Can you check if 'Use Proxy Server' option is ticked under the Cloud->ReadyCLOUD settings page? Also, confirm if the e-mail address of your admin ReadyCLOUD account is used by one of the local ReadyNAS users in your system?
Kind regards,
BrianL
NETGEAR Community Team- HIJAspirant
Hi Brian
Thanks for your respons. Unfortunaly I am away now, so not in a position to check. Will be back over the next weekend.
From my memory:
I am pretty sure the 'Use Proxy Server' option is NOT ticked. If I tick, what else needs to be filled in?
emailadress:
I am the only user. I am pretty sure it is being used, but again, I need to check
I do get an email every night when it shuts down for the night, but I guess that is not what you mean?
so thanks again, let me check when I am back again, pls stay tuned!
kind regards, HIJ
Hi HIJ,
It doesn't need to be ticked if you don't have a Proxy Server. With regard to the e-mail address, just make sure that no local user (Accounts>Users) uses the same e-mail address of your ReadyCLOUD account.
Kind regards,
BrianL
