Smart Connect
2 TopicsAdding an ex7000 to my r7000 with smart connect enabled.
Hi, I am currently using a r7000 with smart connect enabled. I know some of you do not like smart connect, but it works fine here and makes it easy for users. I am about to add an ex7000 and was wondring how it will work with the r7000 with smart connect? If I have to give up smart connect so be it, but I am hoping I do not have to. Does anyone know how I need to go about setting this up correctly?4KViews0likes2CommentsEX7000 with my R7000
Hi, I am hooking up an EX7000 as an extender to my R7000 router. The router is using Smart Connect so 2.4 and 5.0 ghz has the same SSID and the best band is automatically selected for each connected device. I can not see such a setting for the EX7000. Should I just set up both 2.4 and 5 ghz with the same SSID and assume it will work, or will I have to turn off Smart Connect on my R7000?Solved4.3KViews0likes1Comment
