Most RecentMost ViewedMost Likescircuit diagram for the MS510TXPP switch Does anyone have the circuit diagram for the MS510TXPP switch? It's just a few capacitors that are broken, and then it would work again. Unfortunately, I can't see which ones I need to buy. Maybe someone can help. Thank you. Solved
