USB Storage
1 TopicExternal storage issue
I have an R6400 router (latest firmware: V1.0.1.24), and want to connect a Seagate Backup Plus 4TB external drive to serve as back up for several computers in the house. Prior to connecting it to the router I connected it directly to my MacBook Air (running OS X.12.6)--and was coached to download drivers so I could use TimeMachine. I then copied some files onto it (not with TimeMachine). When I connected it to the router, it mounts and is recognized as USB Storage--but it doesn't show the files and reports 0 bytes. I take it this is because the drive now has "special drivers" and so won't work with the router? Is there anything I can do about this--e.g. remove the drivers (and I guess live without TimeMachine). Or am I stuck with a drive I can't use on my network? Thanks for any advice you can give me.Solved
