Unidentified Network
2 TopicsUnidentified Network through wired connection
Hi, I've been having trouble getting a wired connection with my Netgear Extender after we replace our Xfinity router due to the previous one being fried during a storm. It's been giving me Unidentified Network/ Ethernet doesn't have a valid IP configuration. My current setup is a Cisco Xfinity Modem/Router Hybrid Model DPC3941T in the main office on the main floor and the EX7300 Netgear Extender in the basement set up as an extender. WiFi is strong and is working normally, only the wired connection is giving me a hard time. I have some knowledge/experience with troubleshooting and have already tried most of the basic troubleshooting steps to see what was wrong. - Factory reset the extender / modem / router - Replaced ethernet cable - Used a switch between the extender and computer - Did multiple ipconfig /release /renew with no results - Did the netsh commands to reset TCP/IP reset - Uninstalled the network driver / reinstalled with the current driver / tried using older driver - Did sfc /scannow - Gave the extender a static IP - Gave the computer a static IP / 10.0.0.1 / 192.168.1.1 / 192.168.0.1 as gateways I am getting a connection from the ethernet port on the EX7300 so it's not hardware related and more on the computer side. I've probably visited hundreds of sites and forums and tried the solutions there but my situation stayed the same. Here's my ipconfig /all Windows PowerShell Copyright (C) 2016 Microsoft Corporation. All rights reserved. PS C:\WINDOWS\system32> ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : DESKTOP Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : Ethernet adapter Ethernet: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Autoconfiguration IPv4 Address. . : 169.254.144.207(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.0.0 Default Gateway . . . . . . . . . : DHCPv6 IAID . . . . . . . . . . . : 273468522 DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Ethernet 2: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Phantom TAP-Windows Adapter V9 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi: Connection-specific DNS Suffix . : hsd1.va.comcast.net Description . . . . . . . . . . . : ASUS PCE-AC88 802.11ac Network Adapter DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : Lease Obtained. . . . . . . . . . : Saturday, June 17, 2017 7:25:00 AM Lease Expires . . . . . . . . . . : Thursday, June 22, 2017 10:48:43 AM IPv6 Address. . . . . . . . . . . : Temporary IPv6 Address. . . . . . : Link-local IPv6 Address . . . . . : IPv4 Address. . . . . . . . . . . : 10.0.0.156(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Saturday, June 17, 2017 7:25:00 AM Lease Expires . . . . . . . . . . : Saturday, June 24, 2017 7:25:08 AM 10.0.0.1 DHCP Server . . . . . . . . . . . : 10.0.0.1 DHCPv6 IAID . . . . . . . . . . . : 137664502 DNS Servers . . . . . . . . . . . : 75.75.75.75 75.75.76.76 75.75.76.76 75.75.76.76 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Bluetooth Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physical Address. . . . . . . . . : DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Tunnel adapter Teredo Tunneling Pseudo-Interface: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes10KViews0likes5CommentsPowerline Adapter PLP1200 shows up as "unidentified connection"
I got my first powerline because I hated the wireless life. With the new powerline, I installed and prepared it using the instructions from the manual. After hold the security button for two seconds on each adapter, the power light is flashing like it should be and once every light turns green, the computer detects it as "Unidentified Connection". Also, looking at the Network Connections section I see a new device called "Ethernet" with "Realtek PCIe GBE family controler. While connected to the adapter, I am able to access SOME websites like google, youtube etc. I'm not even connected to my wireless! But if I were to goto a website like speedtest.net (I wanted to compare speeds between wireless vs wired vs powerline wired) it takes forever to "connect" and doesn't load/ connect to the page at all.6.5KViews0likes10Comments
