Voip settings
1 TopicS3300 POE Voice Vlan and Auto-Vlan Config
Hi, The documentation is not that clear on setting up a vlan for Voip. There is Voice Vlan and then auto-Voip. Can someone clarify the process. I am up now but there are issues. I created vlan 20 for voice. Added the vlan to the voice vlan including ports 1-20 untagged. Went to the auto-Voip settings the traffice class is set to 6 per the hosted voice providers suggestion. The voice vlan has port 1 on the switch set to vlan 20 its enabled. COs overide is enabled as is authentication. Not sure if they should be or not. Anyway help is appreciated.4.3KViews0likes2Comments
