WIFI 6
1 TopicWAX615 Samsung A20 Android 10 won't connect to AP unless the WIFI 6 is disabled on the AP
Hello, SO I got this AP working so far so good, I have connected several devices with no issues. There is one device that won't connect unless I disable (by UN-ticking) the WIFI 6 setting on the AP. When disabled the phone will connect with no issues. What could be the issue? Is there a fix for this, is this by design? Thanks in advance.1.6KViews0likes1Comment
