We have got your request. Just call Netgear Support Number 1-888-366-0222. We will help you to fix your issues.
2 TopicsReadynas Snapshot usage
Hey together, Attention - I'm not responsible if you damage your NAS. This is not a built in function. Just had again the problem that I'd like to know which snapshot is consuming a lot of space, because sometimes it is so hard to know where, and if it makes sense. Found this script here: https://ownyourbits.com/2017/12/06/check-disk-space-of-your-btrfs-snapshots-with-btrfs-du/ wget https://raw.githubusercontent.com/nachoparker/btrfs-du/master/btrfs-du -O /usr/local/sbin/btrfs-du chmod +x /usr/local/sbin/btrfs-du runned the script on my btrfs volume like: btrfs-du /data/ actually it seems like it could be working. (at least after the change: https://github.com/nachoparker/btrfs-du/issues/9#issuecomment-380427001 ). But I have to verify a little more. Perhaps some people here, which are knowing readynas better than me would also take an eye on it?967Views1like1Comment
