access control
6 TopicsWNDR4500 Access control blocking all new devices on V1.0.1.46
After upgrading firmware to V1.0.1.46_1.0.76, Wireless Filter option desapeared and I could only find another Access Control option under Security, but it seems to not work as I cannot add new lines to the filter and it keeps blocking new devices from connecting to the network. Any hints on how to edit the FIlter List? ThanksSolvedNighthawk X4 R7500v2 Access Control does not work
Frustrating behavior with my device, router firmware version V1.0.3.10 I cannot block a device that is using my network. Advanced>Security>Access Control the checkbox next to Turn On Access Control is checked. I go to the list of the devices that are currently connected, indicating "Allowed" under the status. I click the checkbox next to any of them (for example, an iPad my cousin is addicted to). I then click the "Block" button. I get a popup that asks: "Do you really want to block access to selected device(s)?" I select OK. Screen refreshes, nothing happens; the device still says Allowed! I've rebooted the device twice, no luck! Anybody else have this issue?Solved4.3KViews0likes5CommentsVPN controlling access
I have just got a R7000 router and i am wanting to use the openVPN on it. My main worry is security as it just seems to generate one set of files with no user name or password support for each user. I was wondering, if I use "Configuring Access Control on Nighthawk Wi-Fi Router" to allow only known MAC addresses to access my network, would that also be true when using the VPN, such that if the MAC address was not in the "access control table" it would'nt allow VPN access even although the user had the files. Its just that if anyone ever got access to the files i would have to turn off the VPN feature as they are same files. So I'm hoping that this will be a possible solution to my dilema, using "Access control" features. Hope it makes sense and someone has come across this problem before.Solved4.1KViews0likes3CommentsEx2700 doesn't work if router's Access Control on
I have a netgear router and EX2700 extender. I want access control on at the router but it stops the extender from working. I have tried connecting the extender then adding it to the permitted list at the router and then turning on access control but my phone connects to the extender but the extender will not connect to the router. All otherr devices work fine with access control.3.3KViews0likes3Comments
