add-on Licensing
1 TopicHow do I remove add-on C from WC7520? for use with wndap360
It would not let me add this question without picking one of the predefined models from the list. However I am using the WC7520 with wndap350 and 360 APs I purchased a used WC7520 to add as a redundant backup for the WC7520 that I have already in use. I reset it to factory defaults and set it up for my environment. I could not get it to activate as the secondary controller. After some trouble shooting I found that it has a 10-AP add-on license pack installed, where my original one doesn’t. Under Maintenance> Licensing> Registration I tried to delete the Key, however the check box to select the key is not clickable. Am I looking in the right area to for this to be removed? Or is there a special reset that will remove it? Thanks in advance.Solved4.9KViews0likes10Comments
