cannot connect
1 TopicEX2700 – N300 WiFi Range Extender cannoct connect to router at all.
Hello, I bought this WiFi extender modem, recently. I have a big problem with setting this up, I was trying all the options possible, I searched the forum through for the answer however I did not find it. I was trying to fallow many guides however none of them helped. I was trying to connect extender through WPS, it did not work. Also tried to do the same but using the PIN option, also failed. Then setting up the extender manually, I got the message that the key I put there is invalid (even though the think that it is asking me for should be the same as my password) and it requires 10 hexadecimals values or 5 characters string. And last thing, I tried to set it up using ethernet cable connected to my laptop, this thing did not work out at all, because the mywifiextender, said that I am not connected... Any suggestions what can I do about it? Kind regards3.6KViews0likes1Comment
