cannot connect
2 TopicsEX2700 – N300 WiFi Range Extender cannoct connect to router at all.
Hello, I bought this WiFi extender modem, recently. I have a big problem with setting this up, I was trying all the options possible, I searched the forum through for the answer however I did not find it. I was trying to fallow many guides however none of them helped. I was trying to connect extender through WPS, it did not work. Also tried to do the same but using the PIN option, also failed. Then setting up the extender manually, I got the message that the key I put there is invalid (even though the think that it is asking me for should be the same as my password) and it requires 10 hexadecimals values or 5 characters string. And last thing, I tried to set it up using ethernet cable connected to my laptop, this thing did not work out at all, because the mywifiextender, said that I am not connected... Any suggestions what can I do about it? Kind regards3.5KViews0likes1CommentMystery of two C6300 cable modem router with dual band wifi.
I have identical c6300 installed at 2 homes (not next door) with exactly the same setup and configuration. Both c6300 have same type and firmware level Dlink cameras connected using wifi. Wifi setting is 2.4Ghz, broadcast, auto channel selection, speed up to 450Mbps, wpa and wpa2 security selected. One c6300 connects with no problem what so ever. The other devices triy to connect to 2.4Ghz but will drop. I checked and confirmed as well as change passphrase. Devices that cannot connect include ipad 3&4, kindle hdx, win10 laptop with dual band n. Only device that can connect at both site ont the 2.4Ghz is a LG LGMS323 android phone. Comcast at both site. Let me know if I can provide you with additional details. Thanks3.4KViews0likes3Comments
