connection refused
3 TopicsRN312 shares ok but connection refused accessing admin page, RAIDiator say all OK
Hi All I attempted to recover password, which worked once OK. after rebooting unit I can not longer access the Admin page but the shares are still accessible. From reading previous forums looks like the services config files are corrupted... https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-NV-v2-connection-refused/m-p/1345125#M134922 The unit is a few years old, can anyone help please? Many ThanksBlocked from certain domains. WNDR4300 Router
I have encountered a problem that I can't solve with my router. It seems I am blocked on some domains for some reason and the problem seems to be with the router. I get the ERR_CONNECTION_REFUSED on chrome on sites such as Dxomark.com, but also on various other sites. I can access the sites if I connect my computer directly to the modem so the router seems to be the problem. I have no sites blocked and parental controls are disabled. I have tried changing DNS server to google DNS both on the router and in Windows settings. I have tried changing various WAN settings such as MTU size. I can't seem to find a setting for disabling DNS proxying on the router as has been suggested. I know this question has come up before but none of the solutions have worked for me.SolvedReadyNas Duo V2 - After restart, nothing works
Hi guys, After restarting my ReadyNas Duo V2, I lost all my acces (SMB, DLNA, SSH, Dashboard). I perform an OS reinstall by boot menu, but nothing changes. I tested open ports from my Neywork, only telnet port (23) is open. I tried to connect, but i can't find the credentials... I don't know what to do. I think about perform a factory boot, but I don't want to loose my data, and don't have nothing to backup it for the moment. Someone can help me ? Thanks Lucos3.1KViews0likes7Comments
