copy config
1 TopicCopy configuration from ProSafe GS748Tv5 to ProSafe GS752TP
Hi I am running a ProSafe GS748Tv5 (firmware 6.3.1.4) and was wondering if there's a way to copy the config over to a ProSafe GS752TP (firmware 6.0.1.16). I can copy/restore the config from the GS752TP back over to the GS752TP, however was wondering if it's possible to copy between the two? The error I get when copying the GS748Tv5 "config" file over to the GS752TP is: "Copy: Missing or wrong configuration file header" Any ideas? Thank You!Solved4.2KViews0likes3Comments
