crashplan v4.7
1 TopicCrashplan 4.70 on ReadyNAS Pro 6 with OS 6
Hi, Has anyone managed to get crashplan 4.7 working on OS 6 yet? The reason I am asking is as I know as from 16th May any device that is backing up to Crashplan's servers will need version 4.7. See here: https://support.code42.com/Terms_And_Conditions/Product_Lifecycle_Policy/CrashPlan_For_Home_And_CrashPlan_PRO_Software_Version_Policy And also: https://support.code42.com/CrashPlan/4/Troubleshooting/Computer-To-Computer_Backups_Stop_Working_Between_Version_4.7_And_Earlier_Versions So a bit of history: I installed crashplan v4.4.1 on my Pro 6 (I think i was running OS v6.2 back then, currently running v6.4.0) last year using this guide: https://ptarmiganlabs.com/blog/2013/06/23/netgear-readynas-rn312-hello/ I've had to tweak a few things over time (memory usage and watch handles) but it has been running fine. I use crashplan to backup my windows desktop locally to my readynas and also backup the files on my readynas shares up to crashplan's servers. Crashpplan updated itself to v4.5 and to v4.6 fine but on Monday it tried to update itself to v4.70 and failed and now no longer runs at all. Now the above crashplan links state to be supported that for linux that the kernel needs to be version 2.6.32 or later and glibc needs to be version 2.9 or later. So the kernel version is find but doing ldd --version on my Pro 6 shows that glibc is only 2.19. My plan for today was to upgrade glibc somehow and then see if I could get crashplan v4.7 installed. Unfortunately I have found that crashplan has laredy tried to update itself as stated above and now no longer have a working install. So has anyone else run in to this problem and/or managed to install crashplan v4.7 somehow? (I can't ask crashplan support as a headless Linux install is not supported)4.6KViews0likes2Comments
