daisy-chain
1 TopicOrbi Pro SRK60 su due piani e connessi via cavo Ethernet
I'm considering buying the kit of 6 SRK60 Orbi Pro to create a unique WiFi mesh over two floors. I can make use of Ethernet cable to connect the 6 units among them. In fact, not all the rooms are reachable via WiFi from the Orbi Pro router. Question: can I use the Ethernet port to connect the satellite in a daisy-chain design? I'm able to connect only two satellites directly to the router via cable. The other three satellite will be connected via cable, one after the other. Here below the connection design. All connectoin among units are via Ethernet cable. The Sat 3 is connected to thre other ones (Sat2, Sat4 and Sat5). A couple of Sat will then have other IP items connected like IP cameras. Would this be possible? Orbi Sat4 Orbi Sat1===Orbi Router===Orbi Sat2===Orbi Sat3===< Orbi Sat5 Many thanks.Solved
