device offline
2 TopicsReadynas RND2000 - Remote shows device offline even though it is connected and working
I have been using my Netgear Readynas RND2000 for a number of years and did have readynas remote connected and all was going well. Yes I did have to update the images and software versions to get it to connect remotely but it was working like a charm. This week, I replaced both the hard drives since there were increasing sector errors. The replacement went smoothly but the replacement seemed to reset all the settings / versions and images on the NAS to the original factory settings. I've entered the settings as I recall them being set at prior to the drive replacement and can use the NAS locally like a treat.... BUT I cannot access the NAS remotely using Readynas Remote any longer. I am able to log into Readynas remote and see the device but it shows as offline and will not connect. Can anyone help with some tips, advice, ideas..... I've read through so much on the forum and cannot find a solution. Help ! My system info ============ I am not sure if my RND2000 is version 1 or 2 but suspect possibly v1 as my serial number starts with 1VB3 (?) The local computer is Windows 7 - all other remote computers are Windows 10. I am running Radiator 4.1.16 Readynas Remote image version 1.0.9.78 (perhaps there is a newer version but this is the one I've installed after changing the drives ?) The Readynas desktop version is 1.7.6.28 PS I can also see the name of a device as it was set a few years ago (separate issue but does anyone know how to remove the NAS name from the list)3.9KViews0likes12CommentsReadynas RN102 "disk is full" error + device offline (6.2.5)
Hello, during the past days I experienced the "disk is full" error when trying to copy files from my pc to the readynas disk (4TB / less than 2 used). In the past this happened once and it was due to the snapshots, which I deleted and turned off. To be sure I turned on snapshot access and looked in the folders via the browser interface as well as ssh to be sure no leftovers were inside. Found nothing left. Additionally I wasn't able to update the only 3 addons I installed (the updated package seemed to be downloaded but I got an error after). So I tried to unistall the add ons to install them again, but the device locked me out the http interface and now it gives me the "device offline" message. I tried a OS reinstall that reset the password and IP address etc, but nothing changed (still no http access and disk full error) but I can still access it via ssh and smb (no write access with the pc user anyway). Any suggestion? What can I check/fix via ssh?2.5KViews0likes3Comments
