firmware upgrade
2 TopicsReadynas rnd2000 v2 firmware upgrade
Hi everybody! I'm trying to upgrade the firmware on my (old: 2011) readyNas and could use some help. I had a really old firmware version on it (version 3 - and something) and managed to get it up to version 4. Am I right that the last firmware version for this NAS is version 5.3.12? Could somebody give me any tips on how to get my NAS on this latest firmware (as it won't go there in one step from the version I have on it now)? Your help is much appreciated - thank you!Solved6.8KViews0likes4CommentsProSafe GS752TP - firmware upgrade procedure
Hi all, Can someone please explain the step-by-step process on how to upgrade a ProSafe GS752TP's firmware? The current version of sofware my switch is running is 6.0.1.16 - I believe this is already the highest version, however I'm doing this strictly for learning purposes. I've upgraded smaller "home office" switches by simply dowonloading the firmware and pushing it through a tftp utility (or some switches have a built in utility) so I understand the concept of what I'm doing. I'm not having any luck using the tftp utility, or the built in utility on my switch - which leads me to believe I'm doing something wrong. So if someone could outline the process (with links, applications, etc...) that I'll need to perform the upgrade I'd really appreciate it. I've looked up articles, read the manual, downloaded the how-to however I can't find simple step by step instructions. Thank YouSolved33KViews0likes10Comments
