firmware
894 TopicsR7000 Unable to save to USB after updating to ver. 1.0.12.216
After updating to version 1.0.12.216 I am unable to save to the \\readyshare USB. I can read from it, but I cannot save to it. Previously when I would have problems with just generally accessing the USB, a reboot would take care of the problem. But now restarting or rebooting does not fix this. I'm sure I could take out the USB stick, connect it to my computer, write to it, and replug it into R7000, but that is bypassing part of the usefulness of \\readyshare. Any suggestions on what else I can try to get saving to USB to work again? Any others having this problem with this version? KenSolved2.1KViews0likes3CommentsNETGEAR R8000 AC3200 Nighthawk X6 Random restart and drop all connections
Hi, I have an issue with my NETGEAR R8000 AC3200 Nighthawk X6 router. I was working fine with default firmware V1.0.3.4_1.1.2. Couple of months ago I installed the latest firmware V1.0.4.88_10.1.88_hotfix. It was working fine until yesterday. Now I have following issues. Router stays on (All lights are on as normal but not blinking) but can't connect from any wired or wireless device. Simply wired PC to router also shows no network. Router randomly restarts every few seconds or hours. I keep the router in an open area. So it has good ventilation. I feel the issue arise when router is in load like downloading a large files over the internet. Please help me to fix the issue. Thank you.Solved2.4KViews0likes10CommentsR8000 V1.0.5.88 released?
I have been having connectivity issues with my R8000 as of late (~2 weeks) and finally came looking today for solutions. To my great surprise (and skepticism) there is a new V1.0.5.88 firmware available as of today?!? My incredulity stems partly from the large version bump (1.0.4.88->1.0.5.88) when the release notes state that the release only "addresses security vulnerabilities". I can find no mention of which security vulnerabilities this addresses on the advisory page . Additionally, aren't security patches typically relegated to W in the X.Y.Z.W version ID? All this compounds when considering this device is EOL for some time now... At any rate, curious to hear any more about this mysterious release and to hear if anyone else has tried it out. Best, S1.2KViews0likes1CommentR8000P - most stable firmware?
Hi all... I've had this router since 2018 so it could be age causing this but recently the router seems to be locking up. Problem is, I did a firmware upgrade recently and didn't write down what the old version which was working great. I just figured I'd upgrade because of "security fixes". So the quesation is, what is the most stable version of the firmware for this model? Thanks.Solved2.2KViews0likes4CommentsR8000P vulnerabilities http_basic_auth, weak_password
AT&T give me the message below; is AT&T correct? If so, can the R8000P be fixed? Device R8000P Description There were 2 vulnerabilities found on your R8000P. The vulnerabilities are http_basic_auth, weak_password. These vulnerabilities may allow an attacker to damage your device.2.2KViews0likes7CommentsRouter does not support https protocol R9000 Nighthawk
Some time after I purchased the R9000 router the https protocol stopped being supported and I may only access the admin interface via http Are there any suggestions to restore https access to the admin interface. I have been updating the f/w but I haven’t received any updates in the last 2 years thank you1.9KViews0likes8CommentsLAN Setup: MAC address not accepted by AC2300 R7000p Nighthawk
I have this router now for some years, never had issues. Yesterday I tried to add a wireless door lock. Went to LAN Setup to reserve an IP address for my DHCP server. Once I entered the device, I receive this error message from the router: "Invalid MAC address". Reset router, tried latest and an older firmware version. Same problem. Any ideas? Tried with older and latest firmware: Older Firmware: 1.2.0.22_1.0.78 Newest Firmware: 1.3.3.154_10.1.86 With both I have the same issue. OS: Windows 11 Pro1.5KViews0likes4CommentsNighthawk R7000 openvpn Cannot load certificate file client.crt
Hello I have Nighthawk R7000 running firmware V1.0.11.136_10.2.120 and I was wanting to run a vpn. I followed the instructions about how to turn on the vpn service and installing openvpn. When I try to run openvpn I get this error in the log: 2023-11-10 14:19:55 us=703000 MANAGEMENT: Client disconnected 2023-11-10 14:19:55 us=703000 Cannot load certificate file client.crt 2023-11-10 14:19:55 us=703000 Exiting due to fatal error Now searching here I found that this was a previous issue that was fixed in version 1.0.9.30 but that was back in 2018. Is there any solution now for the latest firmware? thanks8.7KViews0likes19CommentsNighthawk X4S R7800 keeps factory reseting
When I restart my router or it restarts itself it factory resets itself, it started about 4 days ago. 2 days ago I download the last update for it and reupdated it when it reset itself, it seemed to have worked but about 10 minutes ago my internet went out and when it came back I saw it reset itself again. So I downloaded the firewere from a few updates ago and added it to my router to see if it will stop resetting itself. If anyone knows how to fix this problem please let me know because I'm getting tired of having to reapply all my setting, I tried to upload my saved settings file to it but it won't turn anything back on933Views0likes1Comment
