half speed
1 TopicWNDR3800 Low download speeds wifi & wired
On Charter 60mbps, testing at half or less speed on computer wired and wifi. It seems to happen after I plug it in, if I reset it will test at full speeds, then later at half or less. Screenshot of test graph (mix of cat5e & wifi tests) - 60mb straight to router or modem, after a few minutes 20-30 straight to router - 20 and below is wifi. It's only the download, it will half or lower and lock, seems locked at 20mbps on cat5e now. Upload varies but often times even exceeds 4mbps limit. It's like it gets slower every time I test... It may be the router (Netgear WNDR 3800). I've tested another computer and it was making 48mbps on wireless. Seems isolated to this pc on wireless or lan at such low speeds. I do not know anything about the Ethernet card settings but I did put it in 1gbps full duplex, seeing some people say they were forced in half duplex, that didn't make a difference. Wifi also does this, It hardly ever tests at full 60mbps, sometimes though, then it will also go to half like 30mbps - or slower 10-15mbps. I did sift through the archives, most of the threads just kind of died with no solutions. Updated Ethernet card drivers, reset router... Directly connected to modem, 65mbps... Still looking for solutions... Ordered a 5port 1gb switch... Seems to be the router... 65mbps directly connected to modem. Switch may work, was only 10 bucks on amazin.Solved
