inter-vlan
1 TopicS3300 inter-VLAN Routing Issue
I have just purchase an S3300-28X and S3300-52X and am getting to grips with all the features. Most features seem pretty straight forward so far, but I'm having real issues setting up inter-VLAN routing. I've been unsuccessfully banging my head against the wall for a few days now, so hopefully someone here will be able to shine some light on where I'm going wrong. I've factory-reset the S3300-28X and setup a simple configuration for testing: VLAN10 Interface IP: 10.0.10.1 Subnet Mask: 255.255.255.0 VLAN20 Interface IP: 10.0.20.1 Subnet Mask: 255.255.255.0 Port 1/g14 PVID: 10 VLAN Member: 10 VLAN Tag: None Port 1/g16 PVID: 20 VLAN Member: 20 VLAN Tag: None I initially setup the VLANs with the routing wizard, selecting the appropriate tags as untagged. After checking the PVID configuration I connected a workstation to each port with the following manual IP settings: Workstation (1/g14) IP Address: 10.0.10.123 Subnet Mask: 255.255.255.0 Default Gateway: 10.0.10.1 Workstation (1/g16) IP Address: 10.0.20.123 Subnet Mask: 255.255.255.0 Default Gateway: 10.0.20.1 Each workstation can ping default gateways on either VLAN, but the workstations cannot ping one-another. I feel like I've tried every possible setting in the PVID Configuration sections but nothing seems to work. So, could someone please suggest where I've gone wrong or what I should try next? Thanks!Solved5.1KViews0likes3Comments
