internet connection
4 TopicsReadyNAS 314 can't get updates
Firmware version 6.10.10 I have found a number of posts with this problem, but haven't found a solution for my problem. When I check for updates, I get this message: Cannot resolve host name. Communication error. Check your Internet connectioin, DNS Settings, or proxy settings. I know that it is able to access the Internet as every night I receive an email message sent via Yahoo.com, Subject: ReadyNAS Alert Message (nas-02 System: Error) Content: Antivirus scanner definition file update failed due to download failure. Check your Internet connection. Following the solution to other similar problem, I rebooted my modem and router, then the ReadyNAS. I received messages when I rebooted. But the problem continues. I hope someone has a solution! Thank you.Internet won't connect to devices. Help!
I have an N300 router, I just recently got it. At first I had a few problems getting it to connect to my devices. It would only connect to my smart TV and phone. I ended up having to reboot it to try to get it to connect to my laptop because at first it wouldn't. I was successful in getting the internet to connect to the lap to but it would no longer connect to the TV or the smart phone. Why won't it let me connect all of my devices? The network pops up on my devices, I type in the wifi password but they won't authenticate. How do I fix this??Solved30KViews0likes2CommentsC3700 drops connection intermittently
Hello. I have had my modem since installing service almost 2 years ago. I get intermittent wi-fi signal dropped on a daily basis. We never knew how oftern thi was happening until we started to stream movies. Prior to we only used wi-fi or cellphone/tablet usage so we assumed it was our internet signal. TWC/Spectrum has been out recently and noted they found no signal outtage emmiting from their servie and adviced my modem/router fimrware was outdated or not updaetd to the current version. Since I have logged in and found my modem/router automatically updates the firmware. I have tried changing Channels on both networks (2.4/5) and still no changes. I am also using a Netgear range extender WN3000RPv3, however notice the signal drops on both networks not just where i use the extender. Please help!! :(3.3KViews0likes1Comment
