ip management
1 TopicM4300-28G ip management port fails after restart in a stacked configuration.
Hello, we have a stacked configuration from 6 times a M4300-28G switch (firmware version 12.0.2.9), the stack up and running. The ip management port (IP4) is set to vlan 1 and via the web interface all settings en configurations can be seen. After a restart of the stack (all the swithes go down) the web interface fails and de ip address of the ip management port can't be accessed any more. After setting the ip address from the ip management port again (via CLI command line interface port) the ip management port is available again. What can be the reason that the ip management port isn't available after a restart? best regards, Jos LaanSolved7.9KViews0likes14Comments
