lag
2 TopicsGaming Lag - Firmware?
So here's my situation. Recenlty (last couple months) I have noticed significant lag wile playing COD on my PS4. At first I thought it was my controller, because my charactor was running around like I was drunk (looking left/right, etc was exaggerated). Plus there was a .5-1 sec lag between pulling the trigger and my gun actually firing, not to mention I was extremely choppy on comms (PS4 party). It was not happening all the time, but often enough to cause me to look into the issue further. After eliminating my controllers as the issue, I started to look at the router. I factory reset the router and manually configured it. QoS was turned on. After reset, I checked firmware and updated (1.0.3.20 to 1.0.3.24). Problem continued. Fast forward to this week. I updated to latest firmware (1.0.3.26). Performed a factory reset and manually configured router. Again, turned on QoS. Noticed major lag on my game when other devices are streaming content (wife streaming Hulu and daughter on YouYube Kids). One by one I eliminated devices and found the worst lag was beign caused by the iPad streaming YouTube Kids. I check the attached device list on the router config page and saw that my total DL usage was less than 15Mbps (UL was less than 1Mbps). I have a symmetircal 100Mbps fiber connection so bandwidh is not the issue. On a hunch, I grabbed my old WNR2000 router (yes from like 2009), manually configured the wireless settings to match that of the Nighthawk so all of my wirelss devices would connect without me having to reconfigure them. I turned off QoS and tested. Not a blip. I had 1 TV streaming Hulu, the iPad streaming YouTube Kids, my MS Surface streaming YouTube and my phone streaming YouTube and I experinced no lag whatsoever. So my $30 entry-level, older-than-dirt router was handling traffic better than my 1 year old $200 gaming router. Baffling to me. I went back to the Nighthawk and turned off QoS and matched all of the other network settings from my WNR2000. Lag was now worse even when only the iPad was streaming. Had to turn QoS back on, but lag continued, just not as bad. This prompted me to get into these forums to see if this was a known issue. It seems to me like downgrading the firmware is about my only option (as suggested by multiple users from various lag-related posts). As it sits, it will be unusable for FPS gaming unless I am the only one using the internet. So, before I play the download old firmware, factory reset, install old firmware, factory reset, manually configure and test game, I was wondering if someone coud suggest a specific firmware version that woud be recommended. Loading and testing firmware decrementally will be time-consuming. Looking back at the release notes for prior versions, they only list each version as bug fixes and security updates. I am hoping someone with more knowledge of the firmware versions can make an educated suggestion as to what version to use. I assume it would not be a good idea to go too far back in versions. I am really hoping that this is a firmware issue and not a hardware issue. Very frustrating having a useless $200 gaming router that is being out-performed by a $30 entry-level router. Thank you in advance as any help is appreciated.Solved22KViews1like12CommentsNetgear R7000 and R8500 comparison for gaming
I'm considering to buy a new Router-only. I need it to have a very strong signal for a very large house and I want it to be specifically though for gaming (QoS, low lag etc...) And the worst issue I currently have is that when I'm gaming I have to ask everyone else in the house to avoid using the internet or I start lagging very high. So I would like the new router to mitigate this as much as possible! To compare the two I've used the comparison feature here: https://www.netgear.com/home/products/networking/wifi-routers/?cid=wmt_netgear_organic In the R700 I can see things like these that are not available in the R8500: Advanced features for lag-free gaming Upstream & downstream QoS for best gaming & video streaming experience Airtime fairness prevents network lag when slower devices connect I do not know what those features actually are and how effective they are for gaming. Also the R700 specifically talk about gaming while the R8500 doesn't. Can you tell me which of these is the best suited for gaming and why / how? (or if there are other models that are even better?) I'm aware there's a big price difference. I just want to get the best device I can for my two needs (WiFi for big house + best gaming experience possible) and I'm fairly ignorant of these things and need advice. Thank youSolved7.2KViews0likes13Comments
