lan setup
1 TopicAbility to sort the LAN setup list in Netgear genie.
I use the Netgear genie software on an HP Envy Phoenix Desktop computer running Windows 10 with Mozilla Firefox browser version 50.1.0 and R8000 Nighthawk X6 AC3200 Smart WiFi router. I have a long list of items in the LAN setup (Advanced tab --> Setup --> LAN Setup). I cannot sort the list by IP Address or MAC Address or Device Name. I can sort this list in Access Control (Advanced tab --> Security --> Access Control), but it is not the full list of items for which I have reserved IP addresses. When I make a change to any item in the LAN Setup, it goes to the bottom of the list. I have 45 items in the list now and I want to sort them to facilitate finding an item in the list. When an item shows up in the Access Control list, I check the LAN Setup list before allowing the item to connect. I have to search through all the MAC adresses which is tedious. It would be much better if I could sort the list first. I am using Netgear genie Firmware Version V1.0.3.26_1.1.18. .27KViews4likes7Comments
