losing connection
2 TopicsEX6200 Range Extender (losing connections, how to configure from web browser)
I have the EX6200 and am happy with the performance but from time to time it loses it's connection to my router. When this happens I power cycle the EX6200, it reconnects, and I am back up and running for 1-2 weeks, then I lose it again. Curious if there are settings I can adjust to fix this. Also, I am a primarily Linux household, so I am curious if there is a web interface for configuration.1.4KViews0likes1CommentRange Extender losing connection on ethernet cable
I've recently bought a EX6150 wifi range extender and it works just fine when it comes to the extending of the wifi and so. However, I bought this particular model because it also has the possibility to connect a device using an ethernet cable, my pc in this case. Whenever I shutdown my pc, it seems to lose connection over the cable but the wifi still works great. When I wait a while after my pc has started it'll connect again though. Is there anyway to minimise this waiting period? Thanks in advance3.8KViews0likes2Comments
