kiiiieeeeuuuuw
Jan 23, 2017Aspirant
Range Extender losing connection on ethernet cable
I've recently bought a EX6150 wifi range extender and it works just fine when it comes to the extending of the wifi and so. However, I bought this particular model because it also has the possibility to connect a device using an ethernet cable, my pc in this case. Whenever I shutdown my pc, it seems to lose connection over the cable but the wifi still works great. When I wait a while after my pc has started it'll connect again though. Is there anyway to minimise this waiting period?
Thanks in advance
- DarrenMSr. NETGEAR Moderator
Hello Kiiieeeeuuuw
You could try reserving the Ip address of your pc on the router so it does not try to assign it a new on every time it is turned on.
DarrenM
- kiiiieeeeuuuuwAspirant
Thanks for the tip, will try that! :)
