kiiiieeeeuuuuw
Jan 23, 2017Aspirant
Range Extender losing connection on ethernet cable
I've recently bought a EX6150 wifi range extender and it works just fine when it comes to the extending of the wifi and so. However, I bought this particular model because it also has the possibility...
DarrenM
Jan 25, 2017Sr. NETGEAR Moderator
Hello Kiiieeeeuuuw
You could try reserving the Ip address of your pc on the router so it does not try to assign it a new on every time it is turned on.
DarrenM
kiiiieeeeuuuuw
Jan 27, 2017Aspirant
Thanks for the tip, will try that! :)
