m5300-52g3
2 TopicsDHCP Snooping missing on M5300-52G3
Hi, I wanted to set up DHCP snooping, DAI, IP Source Guard on our M5300-52G3. But in the 'Security > Control' Panel I can't found other choice that 'Captive Portal' My M5300 version is '11.0.0.31' I tried via SSH too : I checked in the User Manual and the dhcp snooping menu is there Is that Normal ? Are DHCP Snooping, DAI, IP Source Guard unavailable on M5300-52G3 ? Thx for your answersSolved3KViews0likes8CommentsVlan routing M5300 / GS724T
Hello, I'm planning to split my network in multiples Vlans. I want to use my M5300 to do the vlan routing but i encounter an issue, i can't ping my vlan interface. I'm doing test on M5300 (11.0.0.23) and a GS724Tv3 (5.4.2.25) The vlans are set on the GS724T and the M5300 deal with the routing GS724T : Vlan 1: Untagged : 16-23 pvid 1 16-24 Vlan 110: Untagged : 1-13 pvid 110 1-13 Vlan 150: Untagged : 14,15 pvid 150 14,15 All vlans are tagged on port 24 PC1 and PC2 cant ping each other in the same vlan 110,150 If PC is on vlan 1 ports i can reach the rest of my network. M5300: Routing is enable Vlans 1,110,150 tagged on 1/0/43 (comes from GS724T) Port is set on Trunk, PVID is 1,110,150 on 1/0/43 Routing settings Port Description VLAN ID IP Address Configuration Method IP Address Subnet Mask Routing Mode Administrative Mode Link Speed Data Rate OSPF Admin Mode Forward Net Directed Broadcasts Active State MAC Address Encapsulation Type Proxy Arp Local Proxy Arp Bandwidth ICMP Destination Unreachables ICMP Redirects IP MTU Link State Routing Interface Status vlan 110 110 Manual 192.168.11.1 255.255.255.248 Enable Enable 10 Mbps Half Duplex Disable Disable Active 20:0C:C8:3E:59:15 Ethernet Enable Disable 10000 Enable Disable 1500 Link Up Up vlan 1 1 None 0.0.0.0 0.0.0.0 Enable Enable 10 Mbps Half Duplex Disable Disable Active 20:0C:C8:3E:59:15 Ethernet Enable Disable 10000 Enable Disable 1500 Link Up Down vlan 150 150 Manual 192.168.15.1 255.255.255.128 Enable Enable 10 Mbps Half Duplex Disable Disable Routing Mode Enable ICMP Echo Replies Disable ICMP Redirects Disable I dunno the role of icmp replies/redirects so i tried enable and disable. I can see the route in the routing table : Learned Routes : Network Address Subnet Mask Protocol Route Type Next Hop Interface Next Hop Address Preference Metric 192.168.11.0 255.255.255.248 Local Connected vlan 110 192.168.11.1 0 1 192.168.15.0 255.255.255.128 Local Connected vlan 150 192.168.15.1 0 1 Vlan 110,150 PCs can ping each other but cant reach Vlan Interface. Vlan 1 PCs works normally If I try to ping from Vlan 1 to Vlan 110,150 all my pings go through the firewall and leave my network. Any ideas? Excuse my poor English/grammar/..., this isn't my primary language. ThxSolved5.6KViews0likes3Comments
