management ip
1 TopicManagement IP after upgrade to 10.0.2.13
I just upgraded my M4100-50G-POE+ to firmware 10.0.2.13 (from 10.0.1.16). I was not using IP routing before, and my managment vlan is 1102 instead of the default vlan 1. After the upgrade, I am no longer able to change the management IP. The "network parms" command is still visible in show running-config, but it doesn't let me enter or remove the command from configuration mode. How do I get the switch back to a state where I can set the management IP, other than doing a factory default?2.6KViews0likes1Comment
