management service
2 TopicsManagement Service is offline (RN102)
ReadyNAS firmware 6.8.1 Hi, I have been using ReadyNAS for a while now, I have four in total and they have been 'almost' flawless. This morning, however, when I turned one of them on, the Power light continues to flash indicating an issue. Ran RAIDar 6.3.0 and it tells me both drives are healthy but that the Management Service is Offline. SSH is not enabled on the device currently (i don't run with SSH enabled). I was, however, able to download the logs using RAIDar. I tried to upload them for convenience but zip files are not allowed. Upon searching the forums the most common suggestion appears to be a full O/S partition... but that doing a re-install of the O/S from the boot menu does not fix the issue. I have not yet done this and would prefer not to perform a factory reset unless we have to. any assistance in getting my admin page back up and running would be appreciated. Many thanks. KristianSolvedManagement Service is offline - Due to Plex
I have a RN104 and use it primarily as a streaming media server. Any attempts to use plex (installed on the RN) results in the systems management service going offline in addition to the front interface being unaccessible (when hitting the power button). File sharing continues to work, as does the plex interface, but the RN is not accesible by any other means. The fix has always been to reload the entire system and not use plex. Each firmware release I hope the plex issue is resolved, but its still an issue. Any assistance would be appreciated.
