migrate disks
2 TopicsMigrate X-RAID Disk to new NAS
Hello all... I'm using RNDP400 with 4 x 3TB HDD (X-RAID setup). Firmware already upgrade to OS 6.10.9 and all system running normal for couple of years. Now I just get new RNDP600-100 still in diskless condition in factory setting. So I believe the firmware still OS 4. I need advise the reliable step if I want migrate existing full array of HDD to diskless RNDP600 : 1. Is it possible to switch off RNDP400 then move full array of HDD to diskless RNDP600 (also in power off condition) then just Power ON without upgrading the OS 4 to OS 6? 2. worst case, if I must upgrade RNDP600 OS 4 to OS 6 before do the migration I must prepare new HDD. how big size that OS 4 support? 6TB or 8TB make sense? Please advise.. and thanks beforeSolved155Views0likes3CommentsRND2150 died at power outage. How to save my data?
I've had my ReadyNAS Duo 2150 since 2009. I've replaced disks a couple of times, and now I have two 1TB disks (mirrored). A couple of days ago, we had a short (2 minutes) power outage. After that the NAS won't start. Or rather, it tries to start but shuts down immediately, then tries again, and this happens over and over again. Usualy the start attempt only lasts for less than a second, but a few times it's lasted about 5 seconds. After a few attempts, it gives up and remains powered off. The start attempts include that the fan starts spinning and the blue power light goes on. The blue light fades out as the fan stops spinning. With luck, the problem is in the power adapter, and that it can be replaced. Is that a likely explanation? Are there replacements to be found somewhere? Otherwise, how do I save my data? I've searched forums, and a couple of suggestions I've found aren't really possible: * Replace the NAS with a new, identical one. They are no longer possible to buy. * Replace the NAS with a new, similar one that uses the same file system and whatever else that's required to be compatible. I can't find information about what I should look for in such an alternative NAS. * Insert the disk in a PC, and use a Linux Reader application to read the disk (http://www.diskinternals.com/linux-reader/). This requires (I assume) a stationary PC, and I don't know anyone who use a stationary PC anymore, only laptops. What can I do to recover my data?Solved4.2KViews0likes10Comments
